Rpm issue ideas.... I'm lost....
#45
Tim I have the same issue on my Cafe. Both motors dead on until about 2800 RPM then the port lags between 100-200 RPM. It has been like this since I bought it. Changed the drives from 1.36 to 1.50 and propped accordingly, still the same lag. Bumped power on both motors, AFR's the same, went from 26 to 28 pitch bravo props, still the exact same issue. Did some prop testing and threw a set of labbed 27 pitch Hydromotives on it, couldn't plane for chit but both motors were dead nuts identical, I mean spot on through the entire RPM range. Went back to my 28 Bravos since they have worked the best, and stopped worrying about it.
A thought, have you swapped drives side to side, spinning in to see if the lag changes?
#46
#48
It lags with all 3 sets of props I have tried, never swapped drives but when I first did engines last June they were equal, then all of the sudden they were not and have yet to be, that's one reason I dynode to rule out engine issues, that's why I am trying to look at things that change once in the boat.
I must figure it out because I know its gotta be something dumb, I am gonna try everything I can until I figure it out lol
#50
I don't know how your charging system is wired, but a simple check. Check all battery's and connections. Possible a alternator is causing more draw on one motor than the other. I could be way off, just a idea.
