NEW XR/IMCO 3 bad input seals? NOT >
Old 10-16-2002 | 02:23 PM
  #31
Mr Gadgets's Avatar
Charter Member #601
Mark,
Will that retainer, PN# 841026A2, fit a standard Bravo case? Or is it just for the XR Bravo case? I know the diameter of the two are different. I have the Standard case upgraded to the XR gears.
Thanks,
Dick
Mr Gadgets is offline
Old 10-16-2002 | 08:25 PM
  #32
If you can't use the new retainer you might want to use Loctite 620 instead of 680. 620 is for higher temperature applications up to 450 degrees. 680 starts to loosen up at about 250 degrees. I know that a lot of Bravo's out there are seeing oil temps in that range. Not sure what temps the seal and retainer see, but I would use the higher temp stuff.
Falcon is offline
Old 10-17-2002 | 05:30 PM
  #33
Mr Gadgets's Avatar
Charter Member #601
Falcon,
Thanks for the info, but I want to solve this problem first time out. If I cant machine the stock retainer to fit, I will buy the one from Max Machine Worx. It is expensive, but will solve the problem. That lip goes a long way over the loctite..
Dick
Old 10-17-2002 | 06:33 PM
  #34
Mbam's Avatar
Offshoreonly Advertiser
Dick, it will only fit the XR. Bigger thread and OD on the carrier.
Mbam is offline
Old 10-18-2002 | 06:45 AM
  #35
Mbam's Avatar
Rockie,
Your drive is shipping back today. I am really glad you keep an eye on the oil, this would have been a lot worse otherwise.
Mbam is offline
Old 10-18-2002 | 09:57 PM
  #36
BryanTuvell's Avatar
Donzi33ZX
GREAT INFO and reading.
So questions are........
the $388 (reimbursed?)
And did the drive get cleaned up cosmetically after so much shipping, owner was unhappy with appearance?
I have had great luck with BAM on routine parts, I will use them many times in the future for sure, but after spending 30 minutes to read this post I just thought I would ask those 2 questions.
Bryan
BryanTuvell is offline
TeamSaris
05-03-2006 05:29 PM
Waterfoul
04-21-2005 07:47 PM
open wide
12-19-2004 07:56 PM
Hot Boat
1
07-30-2004 07:57 AM
fred
11
06-02-2003 05:40 AM
