-   -   Outdrive line help (https://www.offshoreonly.com/forums/general-q/340308-outdrive-line-help.html)
Rzide 08-14-2016 07:42 PM
Outdrive line help
Can someone please tell me what this dangling line is off my port outdrive? Also, what do I have to do to fix it right?
http://i1383.photobucket.com/albums/...psng5k8dau.jpg
http://i1383.photobucket.com/albums/...psvrmvl2wh.jpg
Tinkerer 08-14-2016 08:06 PM
The hose with the tan tee is for the speedometer IF you have a water pressure operated one. If you don't - don't worry about it.
Rzide 08-14-2016 08:36 PM
so where and how does it attach back? I don't want it just dangling. It seem the other drive has the same line without the tee just pinched off. Is that the way to fix this? I think my speed-o uses a pickup that looks like a hook under the boat by the plug.
Tinkerer 08-14-2016 08:49 PM
With the drive trimmed way up it hooks into a hole that is hard to find IF you don't already know where it goes. It inserts and then you turn the handle to lock it in.
Invest in a GPS speedometer.
class6 08-14-2016 09:15 PM
Look for the bolt that holds the front zinc on. The pilot tube hole is about 3 inches rear of that. Stick your hand up in there. You'll feel it. If your not using it. Cut it shorter and plug it off and plug it inside the transom also
Rzide 08-15-2016 06:14 PM
Thanks All!
