Hammer knocking noise when in gear over 3000 rpm >
Old 08-20-2016, 03:36 PM
Originally Posted by getrdunn
If insured have him contact his agent. I've had a couple covered over the years. One was a sand bar and other was a dead head at over 80 mph and that one took the drive right clean off. That one I had my hands full trying to get the boat under control.
If memory serves me -- didn't the Stihl boat have a drive fly off and some enormous speed -- I saw the video and it was a wild ride until they got it slowed way down. Glad no injury to you
3pointstar
3pointstar is offline
Old 08-20-2016, 04:48 PM
Received 1,494 Likes on 808 Posts
3pointstar
Wil have to do a search on that one. But ya with twins it's not what I'd call a good time. I couldn't imagine at speeds now a days.
getrdunn is offline
Old 08-21-2016, 09:55 AM
28Eliminator's Avatar
Thanks guys, I'll try to get with him and try swapping the drives. Good idea on the insurance, it probably will cover the cost of fixing it, minus deductible of course.
28Eliminator is offline
Old 10-17-2016, 06:10 PM
A little late on results, but we put the Bravo1 drive on and it still has the noise, but not as loud maybe.
Then after some soul searching (Vacation to Lake Powell) we pulled the motor and don't see anything wrong with anything, like the coupler or flywheel. Then we pulled the valve covers to check for any broken rocker arms or anything bent: nothing. Then we pulled the pan and checked the main bearings and found nothing bad, or anything in the oil. Motor runs perfect by the way.
We are at a lose as to what is making this noise.
Unless someone has any grand ideas, I guess we'll put it back together and see if the noise is gone.
Old 10-18-2016, 10:21 PM
Probably a wrist pin. just put an engine in my mother's boat for the exact same noise. 2001 350 carb engine. It wouldn't make a sound until 2500 rpm under a load. Tore engine down and the pins and pin bores were worn. Everything else looked perfect.
snapmorgan is offline
Old 10-19-2016, 07:51 AM
A blown head gasket will make one hell of a racket above 2500 rpm under load, did you check compression?
TylerBurich is offline
Old 10-19-2016, 08:00 AM
Forum Regulator
Sydwayz's Avatar
Received 1,219 Likes on 527 Posts
Did you check the gimbal bearing, or replace it?
Sydwayz is offline
Old 10-19-2016, 09:28 AM
sometimes you won't hear an engine knock at no load.
dereknkathy is offline
Old 10-19-2016, 12:51 PM
Funny, we were talking about that as a possibility this morning before I checked my email. Knowing it has over 500 hours, I think I have him convinced to go through the motor so he doesn't have any problems with it next summer. Hopefully we can find the cause of the noise. I'll let you know what he decides to do, but if it were me I would rebuild it, now that it's out of the boat.
Thanks to everyone for the ideas!
Old 10-19-2016, 01:40 PM
I just bought one from jasper Engines for around 2K. I don't think that I could rebuild one for that
