Oil Pressure Bypass Valve Question
Can someone tell me which Oil Pressure Bypass Valve is the correct one to use with a remote filter/ cooler setup? My understanding was that 25161284 is the 30 pound valve that should be used with the remote set-up and 25013759 is the standard 15 lb valve used when the filter is in the stock location on the block. However in the Teague article: https://www.offshoreonly.com/article...tech-revisited he's recommending the 25013759. I'm referring to the valve on the block filter pad, not the one in the return tube.
^^^Yup. ^^^
If installing one though, Teague made a misprint or wrote this before it was known about the higher psi valve.
This is straight from GM:
Engines using a sandwich adapter between the block and oil filter to connect a remote oil cooler must use GM # 25161284 oil filter bypass valve (in the location adjacent to oil filter nipple) to compensate for higher system backpressure.
BTW: The following thread on OSO became the 502 Oil Bible thread of basically the wholeinternet.
http://www.offshoreonly.com/forums/g...-hardware.html
Not necessarily. I have no doubt that the bypass is opening but it's not carrying all the oil- my thermostat is plumbed into my remote filter mount and the temperature still moves up and down when running and the lines & filter still get hot. Some oil is pumping through that circuit while I have no doubt some is being bypassed, which leads to my question about whether that would cause lower pressure.
I'd love to. Do you happen to know of a dwarf small enough to walk under my engines and hammer a plug in?? If not, I'll go ahead and try to change it out for a 30lb valve as I mentioned above.
