-   -   Replacement steering Verado 400R (https://www.offshoreonly.com/forums/general-q/340535-replacement-steering-verado-400r.html)
Toffen 08-21-2016 04:12 PM
Hi,
I hope you are well.
I have a power assisted hydraulic steering on my Phantom 25. Its standard system coming with Verado 350 sci and the other Verado 6 inline engines. However, the helm is not accurate enough. I replaced the 40CC helm with a new 50CC helm this summer, but its still not accurate enough. Or less accurate than a Sea Star Pro system I used on my Promax 300.
The steering sylinder mounted to the engine is dead accurate. No slack at all. I presume its the electrical steering pump og helm which are not accurate enough. The inaccuracy cause loss in speed.
I see Latham offer an electrical steering pump. Maybe this is better than Mercury's?
Would an alternative be to replace the electrical power assisted system with a self contained steering system with fx a 1275V CAPILANOŽ HELM and use the already installed steering sylinder?
Thanks!
Cheeers, Toffen
Toffen 10-01-2016 04:20 PM
HI!
Just been informed that Mercury racing upgraded the steering sylinder of the 400R from serienumber 1B245434. It stronger to keep up with higher propshaft heights. Should be interesting to test. I have ordered a 400R with cambered skeg, which should reduce the load on the steering system.
Cheeers, Toffen
steelborn 10-18-2016 08:32 AM
Helm is an issue, it's not precise enough for high performance, I contacted Latham to see what they have as an option, will let you know
Wildman_grafix 10-18-2016 08:39 AM
1 Attachment(s)
Peter in the U.K. Has been working on some interesting stuff for I/O's. Not sure if he has anything for OB's
[ATTACH=CONFIG]560606[/ATTACH]
Toffen 11-28-2016 03:47 PM
Hi!
Thanks!
Cheeers, Toffen
