Reoccurung water pump failures... >
Old 08-23-2016 | 07:12 PM
  #31
F-2 Speedy's Avatar
when it wont flow water, try bumping the starter, without starting it and see if water comes out, just to move the pump a bit
F-2 Speedy is offline
Old 08-23-2016 | 07:18 PM
  #32
Originally Posted by endeavor1
My father fought a collapsing line on his crown line this year. The one in your transom assembly. Pumped water fine on hose and at idle but would close enough at 3000 and up to starve the pump and melt the impeller. We pulled our hair out trying to find the cause. If everything else checks out, replace it and see if it helps. His looked fun but apparently wasn't.
Would it do that consistently or just some time.
Mine burns the impeller instantly at idle.
The hose/drive is brand new.
nsformula is offline
Old 08-23-2016 | 07:31 PM
  #33
SB
What do you lube the new impeller with and what direction do you put the vanes in when you install ?
SB is offline
Old 08-23-2016 | 07:45 PM
  #34
a dry impeller is toast in 20 seconds or less.i use white lithium grease or dish soap for initial start it sounds like you might have a pinhole or a crack in one of the hoses or a loose clamp somewhere in the system.it is a lot easier to suck air than water.when the drive was installed did you use a new o ring and did you use bellows adhesive to hold it in place?without the o ring it will suck air.
mike tkach is offline
Old 08-23-2016 | 07:50 PM
  #35
A small bit of dish soap.
I put the impeller in the housing and use a spare pump shaft to turn the impeller and flip the vanes in the correct direction before installing the impellor and housing
on the shaft in the boat. The rotation arrows are on the housing.
I have enough room that I don't need to pull the whole assembly to do the repair.
Old 08-23-2016 | 07:59 PM
  #36
[QUOTE=mike tkach;4474284]a dry impeller is toast in 20 seconds or less.i use white lithium grease or dish soap for initial start it sounds like you might have a pinhole or a crack in one of the hoses or a loose clamp somewhere in the system.it is a lot easier to suck air than water.when the drive was installed did you use a new o ring and did you use bellows adhesive to hold it in place?without the o ring it will suck air.[/QUOTE
The drive and transom were professionally installed at my dealer.
I had the same impellor issue with the old drive.
When I install a new impeller it always gets it's prime right away and works fine.
It fails after sitting for a while or after being towed to a launch.
This is why I am thinking it's an air lock issue,
Old 08-23-2016 | 08:06 PM
  #37
SB
Originally Posted by nsformula
There is no pattern for failure. Sometimes it failed running on the hose in my prelaunch start up/check over.
Sometimes it fails at initial start up in the water, after being just run ok on the hose.
Don't do this 'prelaunch start up' routine you have, and just start it when dunked. See if this changes the life of the impellar.
I can't tell you how many people have issues with the Bravo set up on the trailer but totally fine when in the water.
SB is offline
Old 08-23-2016 | 08:17 PM
  #38
I know what you mean but it has failed twice in the water.
I launch it, get under way, at low speed both times and a few minutes later, the temp alarm is beeping and steam coming out of the exhaust.
I carry a kit with me, and fix it on the spot, takes about 45 minutes and is a pita next to a hot manifold.
Again, works fine with a new impeller and I enjoy the rest of the day.
Old 08-23-2016 | 08:35 PM
  #39
https://www.gcsmarine.com/content/impellers/impellers
maybe this would at least help you to identify the location of the cause without having to stop and change out another impellor
outonsafari is offline
Old 08-23-2016 | 08:36 PM
  #40
Consistently and it was right after a brand new transom assemble was installed by a dealer. Triple check it
endeavor1 is offline
