Reoccurung water pump failures... >
Old 09-06-2016 | 09:44 AM
  #81
Originally Posted by nsformula
One thing a local tech said I may have a thermostat that is not seating and allowing the block to completely drain leaving the impeller dry after storage.
I'll pull the housing and have a look.
That makes no sense,,
boatnt is offline
Old 09-06-2016 | 09:45 AM
  #82
I did end up taking the drive off, even though it is new, to double check the hose from the bell housing to the transom and it is in perfect condition and installed properly and not leaking.
I took the inlet hose from the transom to the pump off and checked the inside and it is in good condtion, you can see thru it and it is not coming apart on the inside.
I replaced the w/p inlet hose with new hose and put at tee in it .
I know this does not address whatever is causing my problem but it does allow me to flush the engine and prime the w/p if I need to.
Many people have said I have a leak in the suction side of the water pump, which makes perfect sense, but, I have not been able to find that leak with 2 different drives.
Also, as I said, if there was a leak there, why can I put a new impeller on it, and touch nothing else, and have the new impeller pull water right away.
I don't run thermostats and never have an issue with prime.
endeavor1 is online now
Old 09-06-2016 | 09:47 AM
  #83
SB
Was this at a Marijuana party ?
SB is online now
Old 09-06-2016 | 10:50 AM
  #84
Ha ha, wasn't my idea, don't shoot the messenger.
nsformula is offline
Old 09-06-2016 | 02:09 PM
  #85
Do you have a water pressure Guage on the boat? is it possible that a high pumping resistance is what is destroying the impellers. Seems everything on the suction side is new . If not might be a good next step.
buck35 is offline
Old 09-06-2016 | 02:15 PM
  #86
No I don't, should be an easy install though.
Where would I put the gauge, thermostat housing???
Old 09-06-2016 | 02:32 PM
  #87
Block drain or preferably top of intake manifold.
Old 09-06-2016 | 02:56 PM
  #88
SB
Listen everyone as a recap of the thread, he has said and we discovered that his drive also has low water pick ups, and these aren't being blocked off during being run on the trailer.
Each time the impeller has failed, it has previously been run on the trailer.
We are waiting to see if this new knowledge of the situation keeps him from blowing impellers.
If it keeps happening, we move on to other things...if it cures it, we are done.
SB is online now
Old 09-07-2016 | 07:22 AM
  #89
The old drive did the same thing with single water pick up and the new one is hit or miss.
Old 09-10-2017 | 08:43 AM
  #90
What is the current status?
Sonic24 is offline
