frictional losses of 4.25 stroke motor vs 4.0 stroke
Sweet, i used afr 335 cncs for heads since mine are 315' that been re-cnc'd to flow over 400 cfm, 252/260 for .050 duration, .380 lobe lift w 1.7 rockers, 110 icl, 118 ex cl, 114 lobe seperation, 13.5" runner length w race style efi intske, 2000 cfm throttle body, 8.4 compression on 4.25x 4.530 bore, 9.5 compression w 4.0 x 4.500 bore for 502 2.20 runner dia, 2.25 pri dia w 32" primary length w 8" collector. No mufflers
Smitty, all comes from rod angle/side load on cylinder wall, yes may loose % there but they still over come it in the cu in from what I've seen, a couple of years ago several friends of mine all running 632's, kept breaking cranks, all from same deal but they had even more stroke, cylinder wall load..
In my motorcycle superbike motors we run roughly a 3:2 bore to stroke ratio getting 200hp and 85ft of torque out of 1000cc with rev limits around 13k. In our experience we find the power in maximizing the bore, high compression, and fueling. I know that it's apples to oranges, but in a situation where you have to minimize parasitic losses in such a small package because you can't afford inefficiency, and have all of the modern technology and engineering to do so, the stroke is minimized because ain't nobody got time to wait for the piston to finish doing its thing. You do get a longer burn with longer piston travel, but in our case with Moto motors we get two burns while a BBC piston is lollygagging at the bottom of the cylinder with more extreme rod angles not putting energy into direct propulsion.
Smitty, try a simulation using these cam parameters.
On the 548ci
.006 Timing
320.9 intake 328.1 exhaust
.050 timing
266.5 intake 272.5 exhaust
ICL 105 ECL 113
.730 intake lift (.425 lobe) .728 exhaust lift (.434 lobe)
Then for the 509 combo
.006 timing
313.0 intake 317.7 exhaust
.050 timing
257.5 intake 261.5 exhaust
ICL 103 ECL 113
.674 intake lift (.402 lobe) Exhaust lift .676 (.404 lobe)
These cams are obviously large, but then again, looking for max power at 6500 without the help of a blower?. I think this particular program, is mainly looking for MAX power , and probably not factoring in things like idle quality and what not. Either way, I'd be more interested in seeing the power numbers, but mainly, how the two engines would fair up, if they were cammed for their cubic inch, with all else being equal. You can run the numbers with both engines at 9.5:1, and I'll bet the 548 outdoes the 509. However, do the run again, but with the 548 having the lower static compression, and I'll bet it will be close in power. What the 548 loses on compression, it will prob be close to a wash, being that it has more cubes.
As a side note, it appears the lifter acceleration rate of the longer duration 730 lift cam, isn't much faster than the shorter duration, 509 cam with only 674 lift.
Just for fun conversation.
On the 548ci
.006 Timing
.050 timing
ICL 105 ECL 113
.006 timing
.050 timing
ICL 103 ECL 113
On the 548ci
.006 Timing
.050 timing
ICL 105 ECL 113
.006 timing
.050 timing
ICL 103 ECL 113
On the 548ci
.006 Timing
.050 timing
ICL 105 ECL 113
.006 timing
.050 timing
ICL 103 ECL 113
