Loosing fuel pressure >
Old 08-27-2016 | 06:42 AM
Default Loosing fuel pressure
I have twin 95 502 mag efi motors. I go from roughly 32 psi and when speeding up I slowly go loose pressure till under 18 psi in 1 motor. I swapped the vst and mechanical pump and still does it. The sea water pump was replaced early this year. I also replaced the fuel line to tank and the anti syphen valve. Not sure what to do next? And recommendations? Thankyou
Dmsroxstar is offline
Old 08-27-2016 | 06:51 AM
SB
Complete VST with new electric fuel pump ?
SB is offline
Old 08-27-2016 | 06:54 AM
I swapped vst from motor to motor to try and diagnose but still did it
Old 08-27-2016 | 07:03 AM
start at the fuel pick up and start looking.I had one,well 2,1 was in my car,,the antiphon valve got all clogged up and restricted fuel flow.also look at all the fuel lines for weak/collapsing.
or try a new fuel filter.
sutphen 30 is offline
Old 08-27-2016 | 08:27 AM
Sounds like you need a fuel pressure regulator.
Black Baja is offline
