Wierd sea water hose problem
the problem is the muffs don't seal enough to push the water that high. it just leaks out the side of the muffs. the pump will suck it up that high as long as it is any good at all. I just had the same issue. I think it is best to jam hose into hole on transom assy where drive water goes in. run engine and get it primed, then install the drive.
