350 Mag engine wake up
Thanks for any info
Hi Craig, did you mean to say with "stock cam and pistons and vortec heads"? i have been running a super modified 350 mag with a procharger MS1. nothing but trouble . rebuilt it for 3rd time and detonated again as i can t seem to find a re-builder or marine mechanic in my area that can tune the EFI properly . i have a line on a slightly used 350 mag. I would just keep my stainless marine exhaust and and 7 quart baffled oil pan but otherwise not touch the stock. I have been told a Whipple 350 kit can be put on stock to boost it to 465 Hp with good low end torque. Whipple has a stock flashing to tune the EFI chip that works apparently . it does seem to check out, but i wonder if that was your experience and if it still running and reliable.
Thanks for any info
Thanks for any info
Craig also hangs out on "Donzi Marine Restoration Society" facebook page. He is running 95 mph in his 18' Donzi Classic. No problems with his motor. The Blackhawk drive has a high x dimision also.
Look him up,he will help you with what questions you may have.
Mark Oltjenbruns
Thanks for any info
Thanks for any info
