500EFI Help! >
500EFI Help!
500EFI Help!
Old 09-15-2016 | 09:14 AM
GNJ's Avatar
GNJ
Im gonna pull the distributor caps off, inspect and check. Thanks Sydwayz and Mike T for the idea. One other thing worth noting is that the tachs are jumping around above 3000 rpm.
GNJ is offline
Old 09-15-2016 | 09:52 AM
Is there a concern that the advance is jumping around on your port motor scan?
Wildman_grafix is offline
Old 09-15-2016 | 12:41 PM
GNJ's Avatar
GNJ
Yes - one motor shows steady at idle, the other is unsteady and ranges all over from 12-27 .
GNJ is offline
Old 09-15-2016 | 06:57 PM
I believe thats the "Idle stabilization" program trying to keep the engine running smoothly.
sutphen 30 is offline
Old 09-16-2016 | 05:15 PM
GNJ's Avatar
GNJ
Checked both distributer caps and rotors. Checked the grounds in the back of the engine. They all looked OK. Man! this has me stumped.
It seems like both motors are in choke mode. Anybody else think of something to check or try?
GNJ is offline
Old 10-11-2016 | 06:34 PM
GNJ's Avatar
GNJ
OK after much troubleshooting, I see that the engine is only producing 7-1/2 – 8 inches of vacuum which seems to be effecting the map sensor. The Map volts at idle is high with engine at operating temp of 140*. With the engine idling, I tried covering the IAC port in the throttle body to see if it would indicate a vacuum leak. Covering the hole about stalls the engine.
RPM / Map Voltage
Idle – 3.80 V
1000 – 3.72 V
1500 – 2.72 V
2000 – 2.11 V
2500 – 2.11 V
500EFI details
525 cam – by Crane – .610/.632 lift 236/242 degrees duration @.050 114* LS
Dart 308 Heads
9:1 CR
AZM throttle body
80 hrs on motors
Compression on each of the 8 cylinders ~120 lbs
With the new information, can anybody suggest what to do next?
GNJ is offline
Old 04-11-2017 | 07:17 AM
GNJ's Avatar
GNJ
OK thanks to everyone who offered advice - the issue turned out to be the modules inside the distributor which were not holding timing. Replaced and solved the issue.
GNJ is offline
Old 04-11-2017 | 08:45 AM
seems strange that the both went bad at the same time.
mike tkach is offline
Old 04-11-2017 | 09:14 AM
GNJ's Avatar
GNJ
I suspect the modules were going bad for a while and since the motors still ran and I'm no expert, it was hard to identify. One indicated -2 to +42 at idle on my Rhinda scantool, the other +8 to +22.
GNJ is offline
Old 04-11-2017 | 09:27 AM
BUP
MAP at idle is way off it should be 1 V at idle fully warm up engine and about 4.8 V at WOT
I would rescan that for sure
BUP is offline
