Alternator only charging one battery while running - Scarab 33 AVS??????? >
Old 09-17-2016 | 03:04 PM
SANLEONKID's Avatar
Wellllll it was a but easier than I could have imagined. Pulling off the rubber protective cover, I found the POS connection about rusted off underneath. 2 bolts on the alt two nuts for the connectors and two push connectors later I have a new Alt putting out almost 14volts at idle. the pos bolt was only hanging by a thread and broke off as soon as I out some pressure on it with wrench
now I'm able to change out impellers AND alternators...... lord knows what one can learn after 50
[ATTACH=CONFIG]559490[/ATTACH]
Attached Thumbnails Alternator only charging one battery while running - Scarab 33 AVS???????-signal-2016-09-17-102350.jpg
SANLEONKID is offline
Old 09-17-2016 | 07:45 PM
Tinkerer's Avatar
That is a very common problem. The connection on the alternator and the wire I think are under sized for the load. This causes both to overheat. I have had to repair both of mine on the SCARAB. When I rewired the Daytona I oversized a lot of the wires.
Tinkerer is offline
