Lightning or GiL >
Lightning or GiL
Lightning or GiL
Old 09-15-2016 | 11:01 PM
  #61
What's the deal with Eddie Marine???
G-NOTE is offline
Old 09-16-2016 | 08:55 PM
  #62
Nobody has anything to say about Eddie marine manifolds?
Them seem like the best bargain for $1799 and offer dry tails for $500 more.
G-NOTE is offline
Old 09-17-2016 | 04:55 AM
  #63
We have used Eddies on a bunch of boats they are much better than Gil's and easier to work around...
Black Baja is offline
Old 09-17-2016 | 05:00 AM
  #64
Originally Posted by Budman II
Do the stainless marine manifolds allow for the risers to be rotated inward to help with spacing issues? I know the Gil risers bolt to the manifold with 4 bolts, so they are pretty much fixed in one orientation unless you cut and reweld the flange. Seems like I recall that the SM's use some kind of collar to attach the riser.
SM's use a flange with v-band clamp
Old 09-17-2016 | 06:58 AM
  #65
I've recently spent a ton of time comparing the options on dry exhaust and finally settled on stainless marine as the best bang for your buck. My boat had EMI exhaust on it and the quality of the stainless marine manifolds seems to be much better. One example is the flange that mates to the heads. The EMI's also have drain plugs at the bottom of each of the exhaust runners, which I never liked. To totally drain them you would have to remove all of them; removing just the water inlet wouldn't do this because of how the manifold is shaped. On the stainless marine manifolds there is only the water inlet on the bottom and it appears just removing the inlet hose will allow the manifold to drain fully. Finally stainless marine sends you the manifolds first and you take your measurements for them to build the risers from that, which takes a lot of guess work out of whether things will fit or not.
temz is offline
Old 09-17-2016 | 08:54 AM
  #66
Hardin Marine Seaward Series???
G-NOTE is offline
Old 09-17-2016 | 02:08 PM
  #67
Craney's Avatar
Originally Posted by Black Baja
Stainless Marine. Buy them once and then you don't have to pay for a second engine.
My Stainless Marine exhaust are from 1990
Craney is offline
Old 09-17-2016 | 10:32 PM
  #68
Gee wiz just go buy some already. Lol. Gains will be minimal anyway if any on 500 hp or less. Just find a set of used ones here on OSO.
getrdunn is offline
Old 09-18-2016 | 09:16 AM
  #69
If you see some tag me in them, every time I find some they are sold
And the ad is old, or I'm a day late...
When your spending $3k per set you want to get the best bang for your buck. I'm not a baller like most people on here, just a construction worker trying to have nice stuff. Sorry if I pissed people off, I thought the forums were for questions and answers...
G-NOTE is offline
Old 09-18-2016 | 09:45 AM
  #70
Craney's Avatar
I think Sick Stinger on here has some Stainless Marine exhaust in the Swap shop for sale at a good price.
Craney is offline
