Cam and valvetrain longevity....??? low duration high lift... >
Old 09-18-2016 | 07:28 AM
  #111
Full Force's Avatar
anyone know cam specs on these?
https://www.google.com/url?sa=t&rct=...33178914,d.cWw
Full Force is offline
Old 09-18-2016 | 09:10 AM
  #112
vintage chromoly's Avatar
Originally Posted by I.C.U.Lookin
I would love to know the specs of the cam in that build
Here you go:
vintage chromoly is offline
Old 09-18-2016 | 09:22 AM
  #113
Full Force's Avatar
http://www.offshoreonly.com/forums/g...o-results.html
Old 09-18-2016 | 10:43 AM
  #114
Did you ever check cams to confirm lift and duration? Also did you install straight up and degree them? Something is not right? This is obvious as we all have come to the conclusion but need to get to the root of the problem. Those cams should easily make power over 6k.
getrdunn is offline
Old 09-18-2016 | 10:46 AM
  #115
Full Force's Avatar
My buddy Bill degreed them, looking for that a paperwork but I know things were checked
Old 09-18-2016 | 10:50 AM
  #116
Originally Posted by vintage chromoly
Here you go:
Assuming thats a tight lash solid roller by the cam specs. That cam seems like a better fit than tims 241/246. Pulled to 6200 in a 512 incher. Tim has a 540, with less cam. 6 deg less intake, and 7 less on the exhaust on tims cam. And some are surprised tims didn't pull very well to 6000, like he asked for.
Maybe its because those afr heads have such superior airflow, they don't need as much duration. Or, maybe in fact, they actually do, because they don't flow much better than those 15 year old brodix heads. It be interesting if tim unbolted his heads, and brought them to your guy, and see how they stacked up against the 15 year old brodies on the same flow bench, with same parameters.
MILD THUNDER is offline
Old 09-18-2016 | 10:58 AM
  #117
I definitely don't think the answer to his problems is a "741" cam.
Old 09-18-2016 | 11:20 AM
  #118
Heres a test of simply equal vs unequal length headers, on a 525ci bbc. Engine picked up 27hp at peak, 20hp average, and 16ft lbs average torque from 3000-6000rpm.
Id love to see a set of wet stainless marine manifolds bolted onto this engine.
This engine then went back , was freshened up, a set of stock 320cc trick flow heads installed, crane 250/254 hyd roller, and made 725hp, and over 700ft lbs. Then they ported the trick flows, and ended up with 756hp. Hp peaks were at 6000. Torque peaked around 4800.
10.5:1 525ci mill. Dart intake, hvh spacer, 1150 dominator carb. They ran TFX pressure transducers in the cylinder head/exhaust port, to really see what was going on in the engine.
Attached Thumbnails Cam and valvetrain longevity....??? low duration high lift...-20160918_110310.jpg
Old 09-18-2016 | 11:21 AM
  #119
Full Force's Avatar
My buddy bill said pull heads and intakes send to his dad, flow and port them, get perfect factual numbers, order a solid roller off that and make much more HP, my question there is how much more? Or do I run what I got to 150-200 hours and do that then at refresh time?
Old 09-18-2016 | 11:22 AM
  #120
It's a tight lash solid roller.
The brodix "spec" BB2plus heads have been fully ported and blended. 2.300" intake valve. I can dig up the flow data if anyone cares.
The resources are definitely there for Tim to take advantage of if he so desires.
I'd consider tossing one of his cams in the cam doctor as well.
