Help picking out a cam... >
Old 02-07-2017 | 02:42 PM
  #31
Originally Posted by Baja Rooster
Currently the lifters don't have a tie bar, and when I got new pushrods they were the ones sold for the "retrofit" set up. Bear with me as I barely know what the f*** I'm doing with V8s. I was hoping to not need new lifters as I know that these fit and work and don't want to contend with the issues everyone else is having.
By all means if what you have is working and the rollers feel smooth etc keep them as long as there not a bunch of hours on them. You gotta make that call.
getrdunn is offline
Old 03-30-2017 | 05:38 PM
  #32
So after some googling, soul searching, reading tea leaves and what not, it looks like the 731 would be a nice fit without having to reinvent the valve train and should slide in with the existing stuff. It's not a huge step up from the ZZ502 cam, but has a better LSA and breaths a tad bit better where I tend to putt around in the midrange anyways.
Any thoughts on that, and anyone have a 731 laying around?
Baja Rooster is offline
Old 03-30-2017 | 05:53 PM
  #33
I have a 731 sitting on the shelf, but you cant have it,,,its going in my motor.
For lifters, I got my lifters at walmart.
phragle is offline
Old 03-30-2017 | 06:10 PM
  #34
D**k Lol!
Old 03-30-2017 | 06:31 PM
  #35
PM sent
midwest272 is offline
Old 03-11-2018 | 10:41 AM
  #36
Dumb question...
I picked up a 168731 Crane cam which isn’t that much bigger than the ZZ502 cam it’s replacing. Crane recommends their 99896 springs which have installed heights of 150 lbs at 1.900 and 454 lbs at 1.310 and the factory GM ZZ502 springs are rated at 150 lbs of seat pressure and have pretty low hours of use. I know it’s always a good idea to switch them out but is it necessary when they are this close?
Old 03-11-2018 | 11:33 AM
  #37
GPM
How does the open pressure and spring rate compare between the two.
GPM is offline
Old 03-11-2018 | 12:22 PM
  #38
Great question. This is the info someone posted on the Chevelle forum. I’ll dig a little deeper to verify. I guess they look a little soft and were talking about shimming them up for a similar cam. My rev limit is at 5600
“GM at 140#@1.94" ht, 368# rate,”
Old 03-11-2018 | 04:47 PM
  #39
GPM
2 different springs can have the same seat pressure and way different open pressure, which may let the lifter jump over the nose of the cam and bounce a few times on the way closed. Plus the open pressure can be way off if it's checked at 2 different lifts.
GPM is offline
Old 03-11-2018 | 06:07 PM
  #40
I see that now. The GM springs have only 80% of the recommended spring rate it so that couldn’t be good. I’ll find some Isky 8205 units. Thanks, GPM!
