holley throttle cable bracket >
Old 10-12-2016 | 08:19 AM
F-2 Speedy's Avatar
Default holley throttle cable bracket
What are you guys using ? is there a complete kit for a 4150 base
thanks
F-2 Speedy is offline
Old 10-12-2016 | 11:26 AM
https://www.summitracing.com/parts/sum-g1419
f_inscreenname is offline
Old 10-12-2016 | 11:36 AM
I'm going with these
http://www.cpperformance.com/p-341-s...rburetors.aspx
Crude Intentions is offline
Old 10-12-2016 | 11:47 AM
They will also bend if needed depending on your set up.
getrdunn is offline
Old 10-12-2016 | 11:49 AM
SB
Does it come with the cable holder and carb bushing ? Most don't for some dumb reason and prob why the OP posted this thread.
Originally Posted by I.C.U.Lookin
SB is offline
Old 10-12-2016 | 12:41 PM
I went with what icu has and then a cable end kit from cp also. With the standard mercury controls the throw is off, on a set of controls with the different points to change the throw it's not a big deal
indysupra is offline
Old 10-12-2016 | 01:40 PM
F-2 Speedy's Avatar
yes SB, is a complete kit to much to ask for............Indy where you able to get the adjustment correct with that bracket ??
Old 10-12-2016 | 02:20 PM
SB
I use this: http://www.cpperformance.com/p-14094...rsion-kit.aspx
that bolts to back of cable brackets. The brass barrel on the cable will slide on to this.
I get the bushing from where ever. https://www.summitracing.com/parts/mor-64920
Need to get a 1/4" bolt to gothru this and the cable end. I get 2 nuts for the bolt. That way, if you have to take cable end off this side, you can just undo one nut.
SB is offline
Old 10-12-2016 | 02:26 PM
F-2 Speedy's Avatar
Thanks, that first link is much better than the single bolt clamp
Old 10-12-2016 | 07:26 PM
I am adding he same piece from cp that SB posted. I swapped from fuel injection so needed it all
