-   -   Alignment question with off shore mounts (https://www.offshoreonly.com/forums/general-q/341930-alignment-question-off-shore-mounts.html)
cabin fever 10-13-2016 07:14 AM
Pulled my motor out in july for a rebuild. Drive came off pretty easily. Fast forward to now. Dropped the motor back in on Sunday. Didnt think to bring my alignment tool. But figured there was no adjustment anyways. Well now i cant het the alignment tool to go in. Hits the splines on the coupler and just stops. Motor mount on front is a solid tube. Rear bolts are in correctly. What gives?
dunnitagain 10-13-2016 07:21 AM
Sounds like you missing some spacers in the rear mounts.
F-2 Speedy 10-13-2016 07:31 AM
is the coupler to high, low, left or right, there is a fiber washer that go on top of the inner transom plate,
cabin fever 10-13-2016 08:01 AM
Fiber washers and the funky double lock washer are both in. From what i can tell the tool is hitting the bottom of the coupler. Going to buy a dowell and stick in there to help pinpoint it but i dont have any adjustment.
MILD THUNDER 10-13-2016 08:20 AM
Hang front of engine from hoist, remove mount bolts, adjust up/down until alignment tool goes in properly, then you found your alignment. If your engine needs to come up a little in the front, you might be able to make a shim for between the block, and mounting pad on the engine plate. Otherwise, you may have to redrill the angle mounts on the stringers .
cabin fever 10-13-2016 08:34 AM
Does it make sense that id have to make a shim or re drill the holes though? Everythng was fine before. Frustrating to say the least cause i have to wait till a weekend to borrow a buddies forklift and will be gone this weekend so cant do anything till the following weekend.
The motor is currently at TDC so i could drop the dist. In. Would rotating the crankshaft do anything? Im grasping at straws here but i dont understand how anything could have changed
F-2 Speedy 10-13-2016 09:01 AM
1 Attachment(s)
Your installation looks like this ??
MILD THUNDER 10-13-2016 09:07 AM
Was it properly aligned before ? How are the stringers ?
cabin fever 10-13-2016 09:12 AM
Yes sir. My son and i had to actually pull the motor back up cause one of fiber washers slipped the first time.
In my infinate wisdom last night i over torqued one of the rear bolts and stripped out the nut which i plan to replace but i dont think that is the issue as it wouldnt align before, during, or after the torqueing. Looks like i can replace the nut without lifting the motor.
If for what ever reason i do have to pull it again im ordering all new hardware even though everything looked fine to me.
Really pissed at myself for not grabbing the tool. I just dont understand how it could be off as there really isnt any adjustment.
If spinning the motor doesnt do anything. Im gonna loosen all the bolts and try to carefully take the weight off with the forklift and see if that does anything i guess
At least i didnt take the plate off the intake yet. FML.
cabin fever 10-13-2016 09:13 AM
Never checked alignment before since only had the boat a year but the drive came off easily and the coupler looks fine. Everything i have checked looks solid.
