Mrercury 700 dropping boost
Yeah, it would've been helpful to know the EXACT reason but since it seemed to work I wasn't re-fixing it. LOL
That is a Bad Idea running batteries on Both , seen that melt an Altenator on the Port Engine smoke the wiring harness . Then burned the whole back off the boat!
The transients that the combined Charging systems setup, when combined, will wreak havoc on the ECMs. New Belt , New Tensioner then Id swap the ECMs and Boost controllers between Engines and see if the problem follows it
The PCM uses inputs from the MAP sensor, crank sensor (RPM) and the Throttle Position Sensor to calculate the signal it sends to the boost controller. Barring any mechanical issues with the engine you might want to try a new TPS. The TPS is a potentiometer and it might have a bad spot that is causing the output to fluctuate, which might explain why it works sometimes. BTW, the TPS is AC Delco part #213-911
GF?
GF?
