MEFI 4 to Nema >
MEFI 4 to Nema
MEFI 4 to Nema
Old 10-19-2016 | 02:08 PM
Default MEFI 4 to Nema
Does anyone know if there is a gateway to connect a MEFI 4 to a NEMA 2000? I have the Garmin 740s. Running out of dash space for gauges.
1stFormula is offline
Old 10-20-2016 | 10:02 AM
what guages are you adding? maybe this would help. Its what I used. http://www.nolandeng.com/rs11.php
drpete3 is offline
Old 10-20-2016 | 11:28 AM
I called them they said at this time they do not have anything. I want to connect my Garmin 740s. Witch can be wired in by Nemea 2000 or 0183.
Old 10-20-2016 | 12:26 PM
But what guages are you wanting to add? Because although they dont do the conversion you want they can take the signal from your motor and convert it to nema2000.
I used the above device and did tach, oil temp, oil pressure, water temp hmmm forget what else.
Just thought although its not mefi 4 to nema it still may be of use to you.
drpete3 is offline
