What valves to use in EQ320 BBC heads? >
Old 10-20-2016 | 01:10 PM
Default What valves to use in EQ320 BBC heads?
Hi Everyone, I plan on replacing the heads on my 525SC engines with the EQ 320 heads.
I was wondering what everyone was using for intake and inconel exhaust valves?
Thanks in advanced for your opinions.
Baja8808 is offline
Old 10-20-2016 | 02:56 PM
+100 long. With your bore I wouldn't go any bigger than 2.25 intake. Either Ferrea or REV valves Manley don't flow so well. REV flow the best but Ferrea is a close second. Definitely Inconel exhaust valves.
Black Baja is offline
Old 10-20-2016 | 03:21 PM
Heads should work out great for you.
getrdunn is offline
Old 10-20-2016 | 04:12 PM
These are the exhaust valves I put in mine.
http://ferrea.carshopinc.com/product...63828/F1261P-8
MILD THUNDER is offline
Old 10-20-2016 | 04:15 PM
spec sheet
File Type: pdf
Old 10-20-2016 | 09:35 PM
Rookie's Avatar
Bore notch the cylinders if you can while the heads are off. I'm partial to my 2.30"
Rookie is offline
Old 10-20-2016 | 10:10 PM
I plan on rebuilding short block to increase compression to 8.5:1. I'll look into bore notching. Thanks.
Baja8808 is offline
Old 10-21-2016 | 05:56 PM
Looking at these heads too. Thanks for the info guys ,,,from what I read abt them is they r the ones that started pro top line heads in the late 90's. I have a pair of those heads on a 489 like the hell out of them
jdf4068 is offline
Old 10-22-2016 | 10:29 AM
Mild, For the intake valve, did you use the F1232P valve.
Baja8808 is offline
