572's with inter cooled 14-71's >
Old 10-31-2016 | 04:54 PM
  #41
Originally Posted by ICDEDPPL
For what it`s worth , run it rich. According to my knock sensors and AFR gauges the motors are quite a bit happier at low to mid 10`s then they are at low 11`s. @WOT
What is your CR and boost if u dont mind sharing. Seems like u mentioned it before but don't remember off hand. I'm facing this same ordeal but will probably run a year NA. I'd really like to stay under 8.5 so I can throw some boost at them to make it worthy.
getrdunn is offline
Old 10-31-2016 | 06:00 PM
  #42
I figured it to 8.5:1
7.5psi @wot
Dart 345 Iron heads.
EGTs drop 100* with more fuel.
Knock 'noise' goes from 75 to 30 which is low. (at wot)
ICDEDPPL is offline
Old 10-31-2016 | 07:04 PM
  #43
Originally Posted by getrdunn
With that set up I'm coming closer to 8.24 however go to Wallaceracing compression ratio calculator and play with the numbers. Merc might use a flat top also with a bit more valve relief. Either way you can get some ideas
Do we know the cc of the 1075 head?
rob vanharten is offline
Old 10-31-2016 | 07:31 PM
  #44
7.5psi @wot
Are you intercooled, and what blowers?
Old 10-31-2016 | 07:33 PM
  #45
14 apache's Avatar
Here you go The piston has CH 1.381 witch puts it in the hole .096 on a 10.2 deck block. VP is .064 deep with a caliper. I never measured a 1075 to see if the deck is exactly 10.2 and I don't know the CC of the head. You owe me some beers
14 apache is offline
Old 10-31-2016 | 07:44 PM
  #46
Thank you so much!!! What does VP stand for....?
Old 10-31-2016 | 07:48 PM
  #47
14 apache's Avatar
Valve pocket depth is 1/16 of a inch almost nothing.
Old 10-31-2016 | 07:52 PM
  #48
14 apache's Avatar
Pull some boost out and try mid 11s again might save you some fuel and ware and tare and still make the same power. Low 10s the 900s I did would start to misfire on dyno.
Old 10-31-2016 | 09:50 PM
  #49
10-71 ...non intercooled.
Interesting, the boat did go a little slower at the lower AFR .
How did you know it was misfiring?
ICDEDPPL is offline
Old 10-31-2016 | 10:45 PM
  #50
I remember in the early days of engine masters they commented about how all the engines were run quite lean and knocking pretty badly. They didn't like it and I don't know if they made rules different.
hogie roll is offline
