Timing question (setting initial/total) >
Old 11-04-2016 | 03:27 PM
Default Timing question (setting initial/total)
"Thought" i had i timing set. When i bumped throttle to 3k rpms the light started bouncing all over. Brand new motor and ran like a swiss watch on the builders stand with and hei dist. Im running msd with a msd box. Did some reading and sounds like it could be due to the msd box and my timing light with the advance dial. Anyone else heard of this?
cabin fever is offline
Old 11-04-2016 | 05:53 PM
yes,a lot of advance style timing lites will give a incorrect reading.i have a 400 dollar snap on that goes crazy with any msd box.
mike tkach is offline
Old 11-04-2016 | 05:57 PM
Trade him even up and be happy.
getrdunn is offline
Old 11-04-2016 | 06:14 PM
SB
Crazy huh ? And a 25+ year old cheaper Craftsman advance dial light doesn't.
SB is offline
Old 11-04-2016 | 06:24 PM
14 apache's Avatar
Ebay new around 75.00
14 apache is offline
Old 11-04-2016 | 06:51 PM
i had one of those,it took a crap years ago.
Old 11-04-2016 | 07:58 PM
Well chit. If set the dial to 0 and go off 34 degree mark on the balancer and the tab would that work? Planning on going to the water tomorrow. Ill try to find another light.
Old 11-04-2016 | 08:13 PM
Also, Make sure your leads from distributor, are wired properly. Purple, does not go to purple. I wanna say on those, its purple(dist side) goes to green, and purple goes to orange(dist side)
MILD THUNDER is offline
that will work.
Old 11-04-2016 | 08:17 PM
This is most likely your issue. I had the exact same deal happen. Ran fine, but timing light issue.
TxHawk is offline
