500efi Saga Continues >
Old 11-07-2016 | 12:15 PM
Setup
https://i.imgur.com/eKb7CeO.jpg
1MOSES1 is offline
Old 11-07-2016 | 12:49 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Originally Posted by 1MOSES1
What is that mounted above your tailpipes, right on the transom?
[ATTACH=CONFIG]561285[/ATTACH]
Sydwayz is offline
Old 11-07-2016 | 01:34 PM
It does look like like you have the Teague style switchable mufflers????
Griff is offline
Old 11-07-2016 | 01:47 PM
14 apache's Avatar
BTW the one air cleaner looks like its crushed and maybe choking that motor for air. It needs a new one.
14 apache is offline
Old 11-07-2016 | 02:14 PM
MER Performance's Avatar
So after replacing the entire valvetrain to get rid of lifter noise, upon removing engines this year for transom work; the rear exhaust valves are toasted. Heavily corroded looks like reversion. Engine has to come apart for the 3rd time. Anyone have issues with reversion on stock 500efi setup? Exhaust is cmi e top headers. They have been Pressure tested numerous times. No issues.
Before the rebuilds there was a lot of carbon build up but valves did not look like they look now. It's a stock cam, Johnson lifters, isky springs, scorpion 1.7 rockers, and trend push rods. Any help is appreciated. Thinking we may have to go dry to prevent this happening again. Going on 20k for top end rebuilds...should have left them alone.
When you did valve springs and lifters, did you service heads with valve job ? If yes; you have a issue else where.... If you only changed springs and lifters... you have a issue due to your seats and valves that continued leaking after changing those parts. Poor valve seal or leaking exhaust will cause reversion.
MER Performance is offline
Old 11-07-2016 | 02:31 PM
F-2 Speedy's Avatar
Look like solenoids to me, hard to tell
F-2 Speedy is offline
Old 11-07-2016 | 02:49 PM
Panther's Avatar
Frank's Marine Service
And make sure you don't have any exhaust leaks at the heads and also at the tailpipe connection. That will cause reversion too.
When you pressure tested the headers did you apply heat to the collector area and near the exhaust ports? I see a lot of headers that don't leak and as soon as you get heat in them, they begin to leak. People don't believe me until I show them.
Panther is offline
Old 11-07-2016 | 02:59 PM
It's corsa but not attached to anything and aren't operable.
1MOSES1 is offline
Old 11-07-2016 | 03:04 PM
I was told exhaust valves along with valve seals and valve job was performed. Spring pressure was increased but I doubt that would lead to reversion. Heads are going to machine shop Wednesday. The heads were decked not sure what else was done in terms of service.
1MOSES1 is offline
Old 11-07-2016 | 03:05 PM
I will take a picture of the heads. They are literally in mint condition. We did not apply heat when they were Pressure tested.
1MOSES1 is offline
