Tips for Pressure Testing Headers
Lookin for any pointers in Pressure testing cmi e-top headers. The riser seems to be pretty straight forward. Plug up the exit with a bung and pressurize the inlet. Any tips for the tails? Inlet again is easy...no idea what to do with exit where water comes back into exhaust.
All good suggestions. Purchased a 4" inflatable test plug. Didn't work. Tried to position it 10-15 different times. Wouldn't seal. Ended up placing the test plug in the straight section of the pipe and putting an end cap on the end. Still could only get 8-10 psi out of it before it blew out.
What I did with Lightning headers was to put a short piece of 4 inch hose over the inner pipe where it extends beyond the outer collector. Then I put a piece of 5 inch over the collector and clamp it to the collector and two clamps to collapse the other end down onto the 4 inch rubber hose and this clamps the 4 inch onto the inner tube. then apply water to the water inlet manifold. IF there are nuts welded onto the inner tube to hold the tails on just cut a hole in the 4 inch hose to go over the nut. works every time. IF you can't clamp the 5 inch down onto the4 inch tight enough wrap the 4 inch with some duct tape to take up the space.
