Aluminum head valve seat material??
#62
I am glad you have never had to experience plugged sea strainers, after 2 years of running it bit me in the ass and we overheated, the rebuild was a precautionary move as there was nothing wrong with the engines.
But my valve seats still looked brand new and we had a ton of fun with the boat this year!! What is that saying? A picture is worth a thousand words..... Man the bottom gets dirty sitting in the water for 7 days straight boating every day....
#63
I have had clogged strainers, they make this amazing thing called WATER PRESSURE GAUGES.... and WATER TEMP GAUGES.... you should buy some... I live by them.
As far as enjoying the boat? I boated every weekend from second weekend of May in til the last weekend of September, only reason I ended was a trans let go, I could have tossed a spare in and went but decided to look at your buddy's cams and found wear, besides that engines ran fine.
Looking at my videos and pics, seems I use mine gooder then you use yours... I don't just cruise at 4000 all day I actually use WOT ...summer 2016... sure was good to me!!
https://www.youtube.com/watch?v=LDFEOH4q5s4
https://www.youtube.com/watch?v=8pabgc1t9Jk
https://www.youtube.com/watch?v=iurnf_hS8tw
[ATTACH=CONFIG]561899[/ATTACH][ATTACH=CONFIG]561900[/ATTACH][ATTACH=CONFIG]561901[/ATTACH][ATTACH=CONFIG]561902[/ATTACH][ATTACH=CONFIG]561904[/ATTACH][ATTACH=CONFIG]561905[/ATTACH]
#64
#65
#66
#67
I only added my info to try to help, not side with anyone or dismiss a issue, 2004 afr heads, 190-195 seat, 490 oen, hyd roller w .660 lift/250/259 at .050 duration approx, did a valve job every 100 hours when freshening motor( procharged, 14 psi boost), smitty
#68
appreciate it. all good.
#69
How long would you let it hang at 6000? Only asking. What overlap you have?
#70
I have to find the cam card, ive held it with the 1050 pulley at 6300 for 10 to 15 minutes at a time quite a few times but cruise at 3800 to 4500 most of the time, was in a 27 foot boat so never held it for hours on end, td shaft rockers, .080 exhaust seat margin to help pull heat out of valves, Smitty
