Bravo Drive oil cooler-Drew Marine Cool Swirl >
Old 12-01-2016, 03:26 PM
Originally Posted by kevinb230
How is this done?
I don't have any first hand knowledge but I believe the outlet tonthe sea pump is capped off, the drive body is tapped for a hose to the shower cap. I guess that the volume of water is significant.
Baja Rooster is offline
Old 12-01-2016, 04:47 PM
How is this done?
This is how I did mine[ATTACH=CONFIG]562295[/ATTACH]
JaayTeee is offline
Old 12-01-2016, 07:17 PM
Did you do it yourself?
Do you have instructions on how this is done?
kevinb230 is offline
Old 12-01-2016, 07:46 PM
Yes I did it myself, the water hose that would normally supply water to the engine is cut and plugged, you then drill and tap the side of the case... up toward the front is where you have the most room to drill and tap for the larger holes ( I Used 3/4 pipe )...I would have liked to have it toward the rear so that the water would flow past the the inside of the case and pick up heat as it would pass by but I only think you could get by with using 1/4 pipe, which isn't going to move that much water.... At the top, I have the Latham setup Kieth mentioned, I welded a fitting on the top, I also welded some 1/8" stainless around the bottom of the top plate to channel the water down around the sides of the drive,.... Depending on your steering set up, you could do the same with the IMCO shower cap, the hose and fittings are an # 12, got all of that stuff from summit
JaayTeee is offline
Old 12-01-2016, 09:45 PM
Those plates directing water down are a nice touch. Curious, looks like you plugged some of the DWP holes in the side. If so, why? Pressure? I know I ran a DWP lower on one side of my BT and a LWP on the other for a season, noticeable difference in water pressure at cruise.
endeavor1 is offline
Old 12-01-2016, 10:26 PM
[QUOTE=endeavor1;4506025]Those plates directing water down are a nice touch. Curious, looks like you plugged some of the DWP holes in the side. If so, why? Pressure? I know I ran a DWP lower on one side of my BT and a LWP on the other for a season, noticeable difference in water pressure at cruise.[/
I did plug the top holes, my thoughs would be that there would be less drag with the smooth surface, I have 2 the 2 lower plugs in the front of the bullet plugged too, Being that they're not having to feed the engines, I figured that between the 2 in the front and the 3 on the side, they have enough volume to do what I want them to do
JaayTeee is offline
Old 12-01-2016, 10:59 PM
Nice! What drives with what power? Did you have to disassemble the drive to install the taps?
Old 12-02-2016, 01:02 AM
Wow. Nice stuff.................
28cigarettess is offline
Old 12-02-2016, 09:41 AM
standard issue XR's, 575's with iron eagle heads and HR cams, didn't have to disassemble, but had them off of the gimbals to drill and tap.
JaayTeee is offline
Old 12-02-2016, 09:49 AM
Need a picture of your pickups. How did you set them up?
Keith Atlanta is offline
