SBC cooling question?
Im am turning up to 6330 RPM. Limiter set at 6400 RPM. We stay fairly warm here. Boat also stays inside my building where it is in heat and ac year round. I still drain all water from the motor and turn it over every 4 weeks to keep the springs from having constant pressure on them as far as "winterization" goes. I am thinking i may try the smaller reducer with the larger outlet/inlet from crossover to relief on top of tstat housing first then possibly a 140* tstat. As of right now the engine temp will stay fairly constant around 115-123 running in the summer with the Hardin oil tstat housing with remote filter head and 3" oil cooler.
