Bad Cam?
Old 10-05-2002 | 11:56 AM
Default Bad Cam?
If any of you have been following my other posts, I pulled out the lifter that I thought was collapsed and the cam end of the lifter was badly recessed from wear, does this mean that my cam is junk
THRILLSEEKER is offline
Old 10-05-2002 | 12:10 PM
put slick 50 in it and rock on.
audacity is offline
Old 10-05-2002 | 12:47 PM
Ted G's Avatar
See if you can take a macro picture of the cam lobe through the bore and post it. I suspect the hardening is gone and you may have real trouble if you continue to run it.
www.cbpba.com
Ted G is offline
Old 10-05-2002 | 12:52 PM
TS,,,,i have not read your other posts...i waz joking around ...i didn't really think you were asking a question....if you were....by NO means run this engine again!....
audacity is offline
Old 10-05-2002 | 01:04 PM
Scott's Avatar
Charter Member #30
Sorry Tony your done!
Time to go through them and freshen them up!
Not that you want to hear this but Mary and I are leaving for Kelly's in a hour or so If you can make it to CP marina in a hour we can give you a lift
I have Steps & Bubbles!
Scott is offline
Old 10-05-2002 | 02:15 PM
Tinkerer's Avatar
Yes the cam is gone. Sorry to hear that. BTDT
Tinkerer is offline
Old 10-05-2002 | 03:42 PM
FindMe
I'm sure glad I didn't have to tell you what these guys did... Sorry dude, but as they say... Stick a fork in it.. it's done. When a lifter concaves on the bottom, it's because the lifter quits rotating in it's bore, and can happen for many reasons, including not running the motor @ 2500 rpm for 20 minutes the 1st time it is started to make sure the ramps on the cam lobes are able to rotate the lifters, and not start a wear pattern without rotation and eating the cam and lifter instead. If your parts look like these...TRAILER IT, until you can start over. Sorry man, but better to do it now, than too late!
Old 10-05-2002 | 05:04 PM
Not only is the cam bad, but you will have metal circulating thoughout your engine. It needs to be disassembled, cleaned thoroughly and probably replace the bearings at a minimum. If you just replace the cam you will most likely have a bearing failure in the near future from the damage done by the metal.
bobl is offline
Old 10-05-2002 | 05:28 PM
Do you guys think that I should put a new cam in my other (good) engine now to be on the safe side?
Old 10-05-2002 | 05:36 PM
Intolerant1
I swear I have never heard of so many wiped out cams before joining this board. Is it somthing to do with the marine application?
