Better option for Fuel Filter/Water Seperator? >
Old 12-05-2016 | 05:03 PM
Default Better option for Fuel Filter/Water Seperator?
I’m looking for an alternative or better product for fuel filter and water separator.
The ones I have bought in the past are Racor brand. They have the clear globe at the bottom of the filter that screws on and has an O ring.
The problem is that the clear globe only goes on at maximum a quarter turn. If I ever go any farther it strips out. I have tried two different filters and got a new globe but still the same thing.
The vacuum from the fuel pump is enough to keep it sucked on there while underway but while trailering the boat to the lake, it is not uncommon to pop the hatch to find the clear globe and a bunch of gas rolling around in the bilge.
Is there something I am missing here? I mean, shouldn’t the globe go on just as tight into the filter as the filter does to the filter manifold? I can damn near look at the globe and it will fall off.
I am tired of messing with it and always worrying about it.
Thanks in advance.
Zach F100 is offline
Old 12-05-2016 | 05:11 PM
vintage chromoly's Avatar
FST RPM500 FloMax500 Fuel Filter System -12 AN (ORB) ports/ 3 Microns
http://performanceparts.com/part/FST/RPM500
vintage chromoly is offline
Old 12-05-2016 | 05:13 PM
Not cheap, but a quality piece
Old 12-05-2016 | 05:30 PM
bck's Avatar
bck
Charter Member#568
Not sure what you have for mounting options and plumbing, but I'm running these.
http://www.cpperformance.com/p-14586...separator.aspx
Straight bottoms and flat decks
bck is offline
Old 12-06-2016 | 04:53 PM
Thanks for the ideas.
Ill do some digging.
Old 12-06-2016 | 05:06 PM
Sydwayz's Avatar
Forum Regulator
http://www.wixfilters.com/Speciality...eperators.aspx
Not sure if that helps, but you should be able to order through Napa.
Wix makes fantastic filter products. It's all I run for all of my vehicles' oil filter and fuel filters.
Sydwayz is offline
Old 12-06-2016 | 06:19 PM
GPM
In my opinion this one works really well.
GPM is offline
Old 12-06-2016 | 09:32 PM
Check out the fuel/water separator that Summit Racing sells. Been using these for years.
https://www.summitracing.com/search/...parator%20Kits
BenPerfected is offline
Old 12-06-2016 | 09:38 PM
Wobble's Avatar
SORE MEMBER
System 1
http://www.rbssuperchargers.com/Prod...5_--2600-0050B
http://www.system1filters.com/fuel-filters/
Wobble is offline
Old 12-06-2016 | 09:55 PM
Rookie's Avatar
Wix 24770 filter base and Wix 33405 14 Micron large capacity Fuel/Water separator with drain. ~$50
https://www.amazon.com/WIX-Filters-2.../dp/B000CSGT64
http://www.oreillyauto.com/site/c/de...2515&ppt=C0024
Rookie is offline
