Supercharged 540 Camshaft >
Old 12-26-2016 | 12:04 AM
  #71
articfriends's Avatar
Later on i went up to a 252/259 at .050 w about same lift, motor pulled to 6500 instead of 6300 but made similar pump gas numbers (was waaay past limit of blower, blower drive etc)
articfriends is offline
Old 12-26-2016 | 12:39 AM
  #72
I feel maybe I might be better going with some better heads and going with a little smaller cam. Maybe I can make some decent power and not have to waist as much fuel to do it. I don't know. I am still taking in all the great info I have gotten so far. Nobody has really mentioned a custom cam. Might be because I started off saying a shelf cam is what I have been looking at.
powermizer is offline
Old 12-27-2016 | 11:34 AM
  #73
From some of your posts you are asking to build way more of an engine than what your stated goals are. With the camshafts, cylinder heads and a supercharger that are being discussed this boat will be well in the 100mph zone and probably faster than most would ever run a 22 ft boat.
tbanzer is offline
Old 12-27-2016 | 12:04 PM
  #74
My cam thoughts were seeming to small to some. I just want to make as much power as possible without blowing a lot of fuel out the exhaust at a possible 2200 RPM cruise. I had a 24 bravo 1 with 1.36 gears and it stayed on plane nicely at 2200 RPM, not sure what will happen with a 28 prop, I would guess my cruise speed would be around 35 MPH. I hope I will be running a 28-30 bravo 1 prop in the end. looking for around 5500 RPM up top.
Old 12-27-2016 | 07:27 PM
  #75
My build was done with the same mindset...
I used some different components than you're looking at but it turned out pretty good...
Unfortunately, the jury is still out as far as reliability..
I've only put 5 hours on it since dyno.. Working on getting it in a more suitable hull for next year..
Boatally Insane is offline
Old 12-28-2016 | 06:47 PM
  #76
That is some very impressive power with a smallish cam. Nice! I love the Prochargers. I had a M3 on a 509. I had to wait for the power, thank heavens or I would have went through a lot of Bravo drives. As soon as my boat would lay over it was an animal.
