idle adjustment 575 sci >
Old 01-09-2017 | 07:46 AM
Default idle adjustment 575 sci
Is the idle adjustment electronic? 2004
mcprodesign is offline
Old 01-09-2017 | 09:24 AM
F-2 Speedy's Avatar
it should be controlled by the PCM
F-2 Speedy is offline
Old 01-09-2017 | 09:32 AM
The throttle blades are adjustable, but the idle rpm is controlled by the PCM. What kind of problem are you having? I have had to replace the IAC's on mine a couple of times when it got to idling too high when coming off plane
snapmorgan is offline
Old 01-09-2017 | 09:50 AM
1 MAIDEN AMERICA's Avatar
Mine idled high after coming off plane and stumbled going into gear. I cleaned the IAC's and it was better....for a while. I'll replace them next summer. Anybody have a GM part number?
1 MAIDEN AMERICA is offline
Old 01-09-2017 | 09:56 AM
I have a new one in the box at home. I will get it for you later today
Old 01-09-2017 | 10:51 AM
The ecm has a desired idle speed. If you adjust the throttle blades, the ecm will counter with timing changes and/or IAC position. It will do it's best to hit the desired idle rpm, even if that means adding 15* of timing and opening the IAC all the way. Are you having an issue in neutral or going into or out of gear?
Eddie
Young Performance is offline
Old 01-09-2017 | 01:50 PM
It idles about 200 rpms lower than i want . Push the stick forward and it idles where i want
Old 01-09-2017 | 01:59 PM
GM part# 17113099
AC delco # 217-429
Old 01-09-2017 | 09:12 PM
Push the sticks forward and you are opening the throttle blades and throttle position switch together, why do you want 200 more rpm at idle?
proboat-wes is offline
Old 01-09-2017 | 10:24 PM
Cause one motor idles 200 lower than the other. Bump it up and they sound exaclty the same.
It also sounds a little tiny bit loaded up at low idle.
