Promaxx 320 flow numbers >
Old 02-13-2017 | 09:01 PM
  #171
Default Promaxx 317s
So here ya'll go... first real dyno session with the new 317s
[ATTACH=CONFIG]564769[/ATTACH]
File Type: pdf
adk61 is offline
Old 02-13-2017 | 09:06 PM
  #172
SB
^^^Get the sheet with the fuel flow (lbs/hr) and post them up, Thanks ! Airflow would be nice too.^^^
SB is offline
Old 02-13-2017 | 09:27 PM
  #173
Full Force's Avatar
I wish I could run a 108 cam, that's some nice results... did I miss head flow numbers?
Full Force is offline
Old 02-13-2017 | 09:30 PM
  #174
way back
adk61 is offline
Old 02-13-2017 | 09:32 PM
  #175
It's ok SB I wouldn't want anyone to think I'm advertising my heads now would I?
adk61 is offline
  #176
Full Force's Avatar
I will look..
way back
Old 02-13-2017 | 09:36 PM
  #177
Originally Posted by Full Force
I will look..
these are the numbers with my bowl blend before I worked the exhaust ports...
AK Racing 317s Intake .200 = 161cfm, .300 = 234, .400 = 292, .500 = 348, .600 = 378, .700 = 391 .800 = 396 exh .200 = 119, .300 = 162, .400 = 209, .500 = 232, .600 = 261 (w pipe 283) .700 = 272, (288) .800 = 280 (293).+++
adk61 is offline
Old 02-13-2017 | 09:39 PM
  #178
SB
Not saying that.
That sheet does not have much info. I would hope the owner of the engine received more info than that. If he didn't, he didn't get much for his money, other than, well, a sheet.
SB is offline
Old 02-13-2017 | 09:41 PM
  #179
Not saying that.
not my dyno
adk61 is offline
Old 02-13-2017 | 09:44 PM
  #180
SB, i never see you question a dyno sheets validity when it was a marine kinetics build. But foxwells name is on that sheet, so it must be bullchit.
Still havent seen a dyno sheet , posted from anything youve built or dynoed
MILD THUNDER is offline
