Heads Iron Vs alunimum >
Old 01-16-2017 | 08:25 PM
  #31
Originally Posted by SB
Is alunimum like awuminum ?
Only after several capt and cokes....
phragle is offline
Old 01-18-2017 | 07:02 PM
  #32
I think we messaged about my build.
454 bored .060 over
L2399 pistons- 8.75 compression
Crane 134561 Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 3,000-6,000
Intake Duration at 050 inch Lift: 236
Exhaust Duration at 050 inch Lift: 246
Duration at 050 inch Lift: 236 int./246 exh.
Advertised Intake Duration: 296
Advertised Exhaust Duration: 306
Advertised Duration: 296 int./306 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.553 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.571 in.
Merc HP500 heads. 2.25 intake 1.88 exhaust
525sc/177blower
dominator carb
Made 572@5600 on the dyno. That was with the engine on the cool side. After the blower got warm, the pulls flattened out to 550-552hp on the later pulls. I have 60 hours on the setup. Runs great all the time, runs even better on cool days. I suspect a chiller is needed on a 177.
79formula is offline
Old 01-18-2017 | 07:28 PM
  #33
454 bored .060 over
525sc/177blower
dominator carb
Those cams sound good on 454/468. Get as much air in and out of there as possible. You have scoops or enough clearance without. Install extra vents if need be. Intercooler pros and cons.
getrdunn is offline
Old 01-18-2017 | 07:57 PM
  #34
454 bored .060 over
525sc/177blower
dominator carb
Howsmit running with that static compression? what kind of fuel?
phragle is offline
Old 01-18-2017 | 08:11 PM
  #35
Runs perfect. I have been told that is what merc should have used with the small blower. I also run 34* of timing. I use 91 non-ethanol. All marinas and many stations have it.
Old 01-18-2017 | 08:19 PM
  #36
The small or big upper pulley?
phragle is offline
Old 01-18-2017 | 08:22 PM
  #37
I don't know if my pulley is small or big. I do know its 1/2 the diameter of the crank pulley. Makes about 4.5psi to 5psi of boost.
Old 01-18-2017 | 08:59 PM
  #38
Im full of questions tonight...since I am looking at a 242 without motor... how well does it fit back there?? hatch clearance etc....??
phragle is offline
Old 01-18-2017 | 10:01 PM
  #39
Pm endeavour32
He had one years back and was in and out of the bilge I know that for sure.
getrdunn is offline
Old 01-19-2017 | 05:47 PM
  #40
My 242 is an 86. It has about 2.5 inches of clearence. If your boat is an 87 or newer, the hatch is a few inches taller than the 86 and older boats.
