Carb question.  850 vs 800 >
Old 01-19-2017 | 05:25 PM
bck's Avatar
bck
Charter Member#568
The formula MT posted agrees with the carb Pro Systems sold me, so they do seem to actually utilize the formula. If buying an off the shelf carb I'd be concerned with what it really flows verses what the advertised flow is. If you determine you need an 850 and buy one advertised as 850 is it really flowing 850 or...?
Straight bottoms and flat decks
bck is offline
Old 01-19-2017 | 05:35 PM
Originally Posted by getrdunn
Anybody have any experience with
http://blp.com/cart/index.php?main_page=index&cPath=72
I like the 2 cicuit doms.
I have seen alot of them used on open dirt late model engines 20,000-40,000$ engines.
Would prolly be a great carb for big cubic inch marine engine if set up properly.
Very expensive though....cost could be a deciding factor though....
just saying.
chancer540 is offline
Old 01-19-2017 | 05:42 PM
vintage chromoly's Avatar
I thought Holley "wet" flowed their carbs.
I thought carter / Edelbrock "dry" flowed theirs.
Anyone know about the quick fuels?
vintage chromoly is offline
Old 01-19-2017 | 06:06 PM
just saying.
I was looking at a 1250 under 1k. But ya I also noticed they have some high end or at least high dollar carbs as well. Had to look twice at the price.
getrdunn is offline
Old 01-19-2017 | 06:37 PM
Carbs can act strange. One of the last dyno sessions I was involved with was very interesting. Was on a revved up 502 but nothing spectacular and we tried every carb under the sun it seemed. From 750's to 950's. Holleys, including hp's, mighty and speed demons, AED along with a couple others. Can't even remember all of them but the 830 speed demon with choke horn was flat out the best hands down. Really blew my mind. Was not what I expected. If I recall it was up by 10 hp over the others. Overall not a huge difference btwn all of them but was a fun test. The kicker is though on the water the holley hp950 responded the best, idled great and best top end speed. Just sayin... interesting how things can work out. What and how??? All I can say like it's been said before is going from the dyno to the water are two different gigs. May not always apply but definitely can. The guys tuning in the bilge I have respect for especially when their looking for that little extra power. It's there just gotta have patients.
True story on a 24 challenger with a so called baker engineering 500 hp engine I picked up 2 mph on same day with carb tuning only. Carb was an 850 holley dp. That was before all the afr widebands were so readily available and aware of.
getrdunn is offline
Old 01-19-2017 | 07:42 PM
Originally Posted by MILD THUNDER
Looks like an 870 CFM carb for the ZZ502 crate?
http://www.chevrolet.com/performance...02-deluxe.html
looks like bajachicken got it wrong.
mike tkach is offline
Old 01-19-2017 | 08:31 PM
My crate engine 502 with Edelbrock oval port alum heads and moderate cam would turn 5900 rpm with the stock merc Weber/Edelbrock style 750 carb. Properly jetted of course, but it idled great and had great out-of-hole and mid-range too. Personally not a huge believer in extra big carbs. Throttle bodies are different, they don't have to have a vacuum signal to meter fuel.
LT1GMC is offline
Old 01-19-2017 | 09:31 PM
Pretty much identical to my set up: ZZ502 shortblock with Eddy RPM ovals but I put a QF850 on it. The supplier brochure said 750.
Not the first time nor the last.
Baja Rooster is offline
Old 01-19-2017 | 10:32 PM
i am glad you have a good sense of humor.did you ever think about changing you,r screen name bajachicken?it has a nice ring to it.
Old 01-19-2017 | 11:11 PM
Nah... it's actually already the "family/internet safe" version of a nickname, so there's nothing you can do to it that's worse than the original, lol. Baja actually has nothing to do with my mediocre entry level boat, but I spend months down in Baja on a motorcycle by myself.
Now back to our regularly scheduled programming, and the fact that I fear that my equipment may be too small. I can spin my 502 to 5600 with a QF850. Maybe my prop is to small. Something is too small somewhere, dammit.
