engine oil temp sender
What are you guys using, I've looked on line and cant seem to find one, I send a message to Livorsi but have not heard back
thanks |
Summit also carries them if you have one to get the numbers off side. It's a standard sender for many gauges.
thanks, new builds, I don't have one now..........I think the gauges are Autometer but the boats @ the lake
Originally Posted by 33outlawsst
(Post 4522375)
you have to use whatever your gauge requires, not all the same, may look idenitical but mine was 100 deg off, CP can tell you what fits what
Correct EZ............ CP sent me a catalog of the senders for the Autometer gauges
Ken,
Sent you a price list what I was quoted for Autometer gauges and sending units from Diamond Perfomance. I was told the sending unit is specific to the brand of gauge |
Now all I have to do is drive four hours to see if their half sweep or full sweep, it makes a difference. :faint2:
thanks Chris |
Anyone have their oil temp sender in an oil pan port. I know some like it before cooler and some who like it after cooler. I always figured if the the sensor was close to the pump you'd actually be getting a pretty accurate reading. Kinda like my water temp sensor I used a T fitting and installed it there. This was a project in the works that never saw the water so I never had a chance to see how either worked but the locations made sense to me. Especially for water temp sensor if your running x-over an bypass.
| All times are GMT -5. The time now is 11:18 AM. |
