Moisture in heads and top side of Valve cover help. >
Old 01-26-2017 | 11:37 AM
I don't have a water pressure yet its on the list of things to add.
Thank for all the in put. ill look into doing these things and hopefully it will work.
Jfoster is offline
Old 01-26-2017 | 01:43 PM
I had the same issue with a 468 with a blower. Put in an oil thermostat and it went away completely. Then new problems arose and it turned into a 11k rebuild. That's another story. Anyways I had condensation in the same places. Fixed with the oil thermostat for got the name of the one I went with. About 100$ and a few AN fittings and an hour worth of work
Dahlilama is offline
Old 01-27-2017 | 01:12 AM
Originally Posted by mike tkach
the oil does not need to be 212 to boil off the moisture,their have been many threads about this.
True. I was just using the boiling point of water and where it would for sure evaporate any water.
Most likely 160-180* oil temp will get rid of condensation moisture.
Griff is offline
