Changing gear oil in mechanical fuel pump in 525EFI... >
Old 02-01-2017 | 08:54 PM
I have my pump assembly off and in my basement. I'll grab photos tomorrow of where I put the 1/8" pipe plug in the bottom of the housing.
Ryan
Ballistic Beak is offline
Old 02-01-2017 | 10:18 PM
Ryan
Fantastic.. thanks!!
HyFive578 is offline
Old 02-03-2017 | 12:10 AM
I took a deep breath and started drilling. Found the right spot and just did all three pumps. They came out perfect.
Old 02-03-2017 | 09:08 AM
I try to remember to drill and tap everyone of them that comes in my shop. So obviously, I've done a ton of them. I have posted a pic on here before at some point. You can just come up about .200" from the bottom and drill away. It's actually pretty thick at the bottom.Works great.
Eddie
Young Performance is offline
Old 02-03-2017 | 09:32 AM
Eddie
Thanks Eddie. That's exactly what I did. Found the spot where it seemed like there was nothing behind it and drilled. Tapped it with an 1/8" NPT pipe tap and put in these plugs coated with a little Merc. Perfect Seal so they don't back out.
https://www.summitracing.com/parts/VPE-10490
Came out great. Will try to post a pic later.
Old 02-03-2017 | 10:04 AM
Many tap it for the same plug that's found in the top. Same thread as the drive vent and fill holes.
AllDodge is offline
Old 02-03-2017 | 10:07 AM
[ATTACH=CONFIG]564391[/ATTACH]
Attached Thumbnails Changing gear oil in mechanical fuel pump in 525EFI...-img_3239.jpg
Old 02-03-2017 | 10:11 AM
My preference was for standard NPT pipe threads. I already have the taps and there are more options for plugs. Plus, the standard Merc plugs are a pain with the flat top screw; they inevitably strip out. I've replaced every one of them on my boat with these:
http://www.imcomarine.com/cal_store/drain-screw.html
Old 02-03-2017 | 10:16 AM
Good point, I've never had an issue but then again I'm in fresh water
AllDodge is offline
Old 02-03-2017 | 11:27 AM
I see that you went in the bottom. I drill them in the side, but right at the bottom. I go straight under the fill plug on that same flat that the fill plug is on.
Eddie
