low compression 548 dyno testing has begun!! >
Old 02-11-2017 | 06:57 AM
articfriends's Avatar
I didnt get flow sheets when heads came back from Tony Mamo after Bob M had me send them to him (was 2 1/2 years ago) , I did get them in a email but cannot find it now. I will post up pictures of the intake though. After fuking around for past 20 minutes trying to get pic to go thru I go to advanced settings and see until i renew my gold membership its not going to let me post pictures, going to bed.
articfriends is offline
Old 02-11-2017 | 08:24 AM
smitty,i love real world numbers,thanks for starting this thread.i am following it.
mike tkach is offline
Old 02-11-2017 | 08:38 AM
Sonic30ss's Avatar
Thanks for posting this info.
Would like to see the hp/tq curves when you get to it.
Sonic30ss is offline
Old 02-11-2017 | 09:07 AM
F-2 Speedy's Avatar
Text me the pics and I will post if you like
F-2 Speedy is offline
Old 02-11-2017 | 09:18 AM
Awesome testing thanks for sharing!
offshorexcursion is offline
Old 02-11-2017 | 09:26 AM
Cool, im heading to ph store to get this pos note 4 replaced then to shop to dyno. Later on i will renew my gold membership so i csn post b pics agsin, post up the few i sent you andbill comment, thanks, smitty
Old 02-11-2017 | 09:28 AM
I can't wait for the further changes. Exhaust, cam, induction, and so on. You rarely see this kind of development being done. We can protest our theories all day long, but the proof is in the pudding . Thanks for sharing your project Smitty.
MILD THUNDER is offline
Old 02-11-2017 | 09:31 AM
F-2 Speedy's Avatar
pics
Attached Thumbnails low compression 548 dyno testing has begun!!-17513.jpg   low compression 548 dyno testing has begun!!-18003.jpg   low compression 548 dyno testing has begun!!-18134-2-.jpg
Old 02-11-2017 | 09:40 AM
pics
The above pics, first one is port openings of Chinesium intake vs edelbrock victor, gimme fuel on here borrowed me the victor to try and he previously port matched it. I port matched the speedmaster and opened up the 2 tight ports i mentioned before, the writing you see on the face was widths/heights of ports the best i could measure them at pinch point. The second pic is bottom of the 4150 carb, dominator adapter and phenolic spacer. 3rd pic is dom sitting on Chinesium intake
Old 02-11-2017 | 09:57 AM
It be cool, if you had an IAT sensor in the intake . I'd be willing to guess, the IAT's would be a fair amount cooler, with the carb, over the port injection. Especially when the weather heats up a bit in michigan. I remember reading a test where they did this on a Pontiac engine. Carb to port efi. The carb made about 20-25ish hp more if I recall, and the intake temps were quite a bit lower in the plenum, compared to the aftermarket port injection setup. It was like a 500ish hp build.
