Good oil thermostats??
#41
I would say the hardest thing to do was figure out how I wanted to mount them once I see how I did it now I think that's an ideal way to mount them, The product looks to be a very nice product
#47
Well so far not happy with these, oil pressure is dropping to 40-45 at WOT, going to bypass and make sure it's the stats, but I changed nothing else in system so has to be...
Also temp readings in pan are 250-285??? No way is the stat opening up.... water is 44 degrees they should have no issues cooling,[ATTACH=CONFIG]566790[/ATTACH] sender is in oil pan
#50
