Blower cams
Old 02-28-2017 | 08:25 PM
  #31
I find this article kinda interesting,,may won't to note the split on the winning cam.
http://www.superchevy.com/how-to/eng...ower-cam-test/
sutphen 30 is offline
Old 02-28-2017 | 08:48 PM
  #32
Cool article. Pretty clear the big cam simply won. Bigly.
Not surprising that much cam split did well, when you look at the flow numbers from a stock LS3 head.
MILD THUNDER is offline
Old 10-18-2017 | 10:37 AM
  #33
Originally Posted by JRider
I believe my Lunati cam for my 575sci is 240/[email protected] .642/.642 114ls 110icl, I havnt even fired the motor yet but I wish I would have went a little bigger and did the 4/7 swap. Also not sure about the 5* split. At this point I dont think it would be worth the investment as I dont have anything to put it in. So, with AFR325 cnc chambered, stripped 871 with whipple chiller, stock 502 bore, 8.25:1 CMI ETops...what is my safe estimated HP on 93? The problem I see is supplying enough fuel with the dump truck injection system.
im currently doing the same thing to my 575sci, going with the Eddie young injection tho, what would the 4/7 swap bring to the table? i remember reading about it awhile back but thought it was on a small block. is yours still a 502 JRider?
LTZCrew is offline
Old 10-18-2017 | 11:58 AM
  #34
4/7 swap makes the firing order the same as the LS and 8.1, it makes a few more horsepower, about 15? cant exactly remember, but I was told it has to do with crank shaft flex. All that needs to be done is swap the wires on the cap. NASCAR uses that firing order as well.
Yes, mine is standard bore 502, I would have went to a 540 if I knew my injection could supply it.
JRider is offline
Old 10-18-2017 | 12:12 PM
  #35
F-2 Speedy's Avatar
single swap, 4/7......C swap......4/7 3/2 ( double ) minimal gain maybe less than 10hp @ over 6000 revs from what I've read, I ran C-swap in my 540's, you can really hear a difference through the headers. I think the Pro stock guys started this way back in the day, it is suppose to be easier on the crank and bearing's tho.
F-2 Speedy is offline
Old 10-18-2017 | 02:40 PM
  #36
with that cam how high are you planning on spinning it? im in the same boat on my build currently
LTZCrew is offline
Old 10-18-2017 | 03:11 PM
  #37
Default Stock ls3 flow numbers
0.617/0.595-inch lift split, a 231/248-
if the numbers inked below are confimed correct then it does make sense with what I would consider to be a funky cam. The exhaust flows like 2/3 the intake vs more common heads 3/4 especially aftermarket. Ratio varies lift depending but in a nutshell I can see how they came up with that grind after looking at the flow numbers.
getrdunn is offline
Old 10-18-2017 | 08:39 PM
  #38
Rookie's Avatar
I run the 2/3, 4/7 swap and you can definitely tell the difference. Kinda takes the bark away from the big block. It sounds tame, but smooth.
Rookie is offline
Old 10-18-2017 | 09:04 PM
  #39
i didn't know you did that. Gotta be easier on inners but not as big of a grin on your face heading out grand haven channel. Lol... I knew the 4/7 swap tamed down and definately have a sound of their own so I can only imagine 2/3-4/7.
getrdunn is offline
Old 10-19-2017 | 07:28 AM
  #40
6000 but I am not sure where peak power is at. I actually spun it to 5800 with stock cam, not sure how much HP dropped off but the boat was fun to drive.
JRider is offline
