Air Fuel Ratio Meter >
Old 03-20-2017, 10:10 AM
Received 4,326 Likes on 1,241 Posts
You can see the 02 bungs on top of the Lightning headers, there lasted 2 plus years ..( No reversion, good AFRs and low heat.)
My current application, I believe they die after a season due to heat.
ICDEDPPL is offline
Old 03-20-2017, 10:24 AM
Nice setup, guess the main issue is the sensor will not last long. Appreciate the input, will look around
Currently have EMI
AllDodge is offline
Old 03-20-2017, 02:56 PM
Currently have EMI
I have EMI exhaust with bungs.. Don't have much time on mine yet but seems to work ok..
I went with the AEM "failsafe" gauge. does only read one bank tho'...
It reads A/F & boost / MAP
You make it record your A/F vs MAP when you know the engine is running good, then you can set it so it'll set off an alarm if it falls out of the parameters....
Has a ground output when in alarm mode.. could connected it to a warning light or even a rev limiter... One less thing to constantly watch..
It also datalogs...
Boatally Insane is offline
Old 03-20-2017, 04:20 PM
I like it, thanks
AllDodge is offline
Old 03-20-2017, 11:41 PM
Innovate makes one that fits in one small gauge hole that will read both banks. I run the single bank Innovate MTX-L model full time. Have been doing so for 7 years. The feed back is invaluable.
Trash is offline
Old 03-21-2017, 05:41 AM
the 02's that are used are honda/acura and heat should not effect them
ezstriper is offline
Old 03-21-2017, 07:38 AM
Originally Posted by getrdunn
You can always run one temporarily and tune on cooler day and call it good also. Check it from time to time to confirm your content. To many gauges can get you in trouble also. Meaning safety reasons.
I would add that they would be about as useful and used as offen as volt meter gauges. With carbs, once the jetting is set, you are good to go.
BenPerfected is offline
Old 03-22-2017, 10:13 PM
There was a case here where someone popped a vacuum port cap off and melted an engine. It can be helpful for catching trouble.
Baja Rooster is offline
Old 03-24-2017, 05:59 PM
Received 1,493 Likes on 807 Posts
Not if your Jim Valako when he ran carbs. He'd change jets from day to day depending on weather. I use to laugh at him but if he can find another 2-5 hp on any given day he will. Lol. He'd go by plug readings though.
getrdunn is offline
Old 03-24-2017, 06:40 PM
So every time the weather changes you got back to the dyno? 5 HP wouldn't show on the GPS.
