Distributors >
Distributors
Distributors
Old 03-20-2017 | 10:27 PM
Default Distributors
is most everyone running the msd dist 85551 in conjunction with daytona cd-1 or msd box. Any Mallorys or anything else. Just trying to narrow down the list. Msd might be considered to be great but... looking for aftermarket.
Tks
getrdunn is offline
Old 03-21-2017 | 05:44 AM
MSD the worst marine use dist out there, look at the inside of one after a season, looks like something found in a model A sitting in a field for 40 years. They love to just die at any given time(MSD=may soon die) I have had great luck with H/P HEI's cheap, reliable...
ezstriper is offline
Old 03-21-2017 | 06:35 AM
Getrdunn will be running roots blowers, I don't think an HEI will clear them.
The downside to MSD, is the corrosion issue. However , coating the distributor internals with CRC-SP400 spray, prevents it. Takes about 5 bucks, and 5 minutes. My MSD pro billet distributors look like new inside, after 7 years.
You can also use a merc distributor with a daytona box. Daytona sells a modified rotor for it that you will need.
MILD THUNDER is offline
Old 03-21-2017 | 06:40 AM
small cap distr from the 91 and up GM cars or truck,,bb or sb chevy will work.
sutphen 30 is offline
Old 03-21-2017 | 08:14 AM
I use MSD 8560 Marine Pro Billet Dist., I installed their new plated reluctor wheel a few years ago, they don't corrode like the non plated wheels, mine are 9 years old and run great
253 is offline
Old 03-21-2017 | 10:36 AM
bck's Avatar
bck
Charter Member#568
I still have the same T- bolt IV distributors that came with the Formula in 86. Hard to argue with that lifespan.
Straight bottoms and flat decks
bck is offline
Old 03-21-2017 | 11:02 AM
Msd bought Mallory and shut line down. I liked Mallory much better than msd. If I could find a new pair I'd run them now.
5050 is offline
Old 03-21-2017 | 11:07 AM
vintage chromoly's Avatar
I'm running a Mallory marine distributor with the CD-1 Daytona box.
It's a small cap distributor. I bought it after MSD bought Mallory and it came in a Sierra marine package. Somehow Sierra is involved with the Mallory marine stuff.
Anyhow. The Mallory distributor is a much nicer piece than the MSD in regards to construction.
vintage chromoly is offline
Old 03-21-2017 | 11:51 AM
articfriends's Avatar
Ive used msd distributors, looked like they were immersed in salt water after 2 years, sent back and they replaced everything for like 90$, bought clear coat spray in spray can and coated the fawk out of them inside, looked like new 10 years later, fwiw, Smitty
articfriends is offline
Old 03-21-2017 | 12:06 PM
F-2 Speedy's Avatar
There's a few new Mallory ones on ebay
F-2 Speedy is offline
