New 572 builds hp guesses
#51
It definitely be worth the test to try each carb, especially if Norm is willing to do that free of charge. I'd be trying both carbs, see what happens, then make a decision. Its a no lose situation.
Which model dominator did you get Rob? Not all dominators are the same. Just booster design can have a huge impact in the carb's performance. An Annular high gain style booster, can make much better torque down low, and sometimes better top end HP, then a down leg.
#53
I would love to see tims QF1050 on a 750, 850, 950 hp motor against a 1050 dom, if they both made 654/655 hp on my 548, they both flow 1050 cfm at same flow standard is there any reason the equal flowing dominator other than looking cool should out perform it anywhere?
Like you said earlier, its not just the cfm rating. How the fuel is atomized, distributed, etc. If the 4150 style carbs were all thats needed for a 750hp deal, holley, quick fuel, demon, prosystems, and many others wouldnt have sold many dominators. Bck here made more power with a dominator on his 540 after swapping the 4150 carbs and what not .
Heres a good read from prosystems about this topic
https://prosystems.websitetoolbox.co...in-cfm-6223685
#54
With that being said, do i think they are hands down the best carb for every application, no. And once in the boat, they need some adjusting for sure. As have most carbs ive seen, after they come off the dyno
#55
Anyone have $1800 to burn ? Would love to see real world tests on one of these.
http://www.silverbackcarbs.com/index.php
#56
#57
#60
