I put a new 12k in my mainship forward stateroom last year about $1250, looking at replacing the 16k in the main salon this year.
Exactly what I did also.
Originally Posted by MILD THUNDER
(Post 4542626)
On mine, I only drilled a hole in the boat for the discharge. For the intake/supply water, I tee'd in to my sea strainer with a valve. I just have to open the valve when I turn the a/c on , and close it when I'm done. The strainer also filters out the crap.
I can help you with install if you want a Justin just let me know, sounds like a good day of beer drinking lol
Originally Posted by ICDEDPPL
(Post 4542921)
Ever mount the unit on some dampners? Mine popped a refrigerant line (100* weather and 7 hours from home of course) . I have it on vibration pads now but i`d like to find something spring loaded...just a thought
(Post 4542921)
Helping even when he`s on vacation... what a buddy!:D
Originally Posted by ezstriper
(Post 4542958)
they come with a thick mounting pad, never used more than that, did some performance boat installs and never had a failure
the main thing had had to deal with on performance boat apps is the water pickup, most do not want to add a scouped thruhull(understandably) without this style will loose prime to pump when you run, so you have to bleed everytime you use, can be a pain we set up with a bleed valve now and makes it easy
YUp, I have to bleed my strainer for the water level to come up. Joes strainers are higher I don`t think he has that issue.
| All times are GMT -5. The time now is 05:24 PM. |
