What is wrong >
What is wrong
What is wrong
Old 04-03-2017 | 03:58 PM
We have wideband on it.
mggdoors is offline
Old 04-03-2017 | 04:01 PM
Havent dine plug reading. That is next step when leaning her out a hair
mggdoors is offline
Old 04-03-2017 | 04:16 PM
Be careful 12.5 is right near the comfy zone. new plugs - wot - pull tethers.
getrdunn is offline
Old 04-03-2017 | 04:17 PM
When you plan on installing blowers?
getrdunn is offline
Old 04-03-2017 | 04:22 PM
As soon as i find a good deal I can afford. Also. Plug gap is .045 7 heat range ngk
mggdoors is offline
Old 04-03-2017 | 05:02 PM
If your plan is to put huffers on, then do it. That's where your HP is, Anything else is just chasing your tail in circles. It's hard to build a low comp motor and get the HP out of it. That's what the blowers are for. IMHO what you have is 1/2 of a build.
gofastboater is offline
Old 04-03-2017 | 05:22 PM
You'll be happy you built low comp builds after you strap the blowers on. You'll be able to safely throw boost to them and make some good power. Just gotta bite the bullet for a while. You just need to keep in mind that the new components will soon compliment your builds.
getrdunn is offline
Old 04-03-2017 | 06:54 PM
I see you have a set for sale. We run a sherwood crank mount waterpump can that be used with that setup or does it require the mercruiser style
mggdoors is offline
Old 04-03-2017 | 07:39 PM
I've only seen one of those crank mount pumps on an older boat I owned and from I recall I don't think they would.
getrdunn is offline
Old 04-03-2017 | 07:48 PM
Your compression is too low , your cam is bleeding off what little cyl pressure you have . Iits not timing , carb size, tuning or anything else . You not only knocked 1.5 points of static compression but you also severely lowered your dynamic compression by a later closing intake valve .
billy boats is offline
