Newbie building a performance 454 needs experienced advise >
Old 04-12-2017 | 06:33 PM
  #71
SB
8.65:1 compression pistons with 119cc heads should look like this;
SB is offline
Old 04-12-2017 | 06:44 PM
  #72
SB
Found info on the flat tops with 2 valve reliefs:
Piston Top: Flat-Top 2-Valve Reliefs, Chamfered
Pressed Pin
Comp Ratio: 8.72:1 w/100.9cc Heads, 7.73:1 w/119cc Heads
SB is offline
Old 04-12-2017 | 07:00 PM
  #73
14097044 gen 6 forged crank.do you see numbers looking up under pistons?
dereknkathy is offline
Old 04-12-2017 | 07:15 PM
  #74
SB
Yup.
Part#14096983 - 1-PIECE FORGED STEEL 454 CRANKSHAFT- 1053 STEEL
DESCRIPTION
This forged steel crankshaft (forging ID #14097044) is made from 1053 steel. It is a Gen. V & Gen VI 454 (7.4-liter) big-block design with the one-piece rear main seal. It is externally balanced.
SB is offline
Old 04-12-2017 | 08:05 PM
  #75
Flat tops for a 454, from JE, are for forced induction applications. Usually the low 8:1 range with a typical bbc head
MILD THUNDER is offline
Old 04-12-2017 | 09:22 PM
  #76
Originally Posted by AllDodge
I'm unable to find this number
14097044 sorry
pjv911 is offline
Old 04-12-2017 | 09:26 PM
  #77
No numbers under pistons but there is a logo I don't recognize.
pjv911 is offline
Old 04-13-2017 | 07:46 PM
  #78
Ok well since I am going to need more compression which pistons are the better choice? The four critical points of interest are,
# 1 Compression ratio of 9.5-9.7 cr (unless otherwise recommended)
# 2 Weight to match the dimple rods and 14097044 crank balance
# 3 Non floating pressed wrist pins (for the forged dimple rods)
# 4 Must be forged
I do't really want to spend top $ for these pistons but dont want the cheapest junk either.
Bore size is .030 over (4.280")
Gasket crush size .039
As far as the space between the top ring and deck will depend on piston choice I am assuming.
Engine specs as of my current configuration
ZZ502 hyraulic roller camshaft (will be using the original lifters and pushrods)
Dual plane factory GM brass insert high rise manifold
Edelbrock 750cfm marine carb
Comp cams 1.7 pn 1620-16 rockers
Stellings aluminum exhaust manifolds with thru hull dry pipes
RHS (Pro-Topline) cast iron rectangular port 118cc (might be 119) chambers, 2.19" intakes and 320cc intake runners
Gen 6 4 bolt 7.4 block
Factory forged dimple rods w/ 7/16 rod bolts (is an upgrade to new arp bolts needed?)
pjv911 is offline
Old 04-13-2017 | 08:19 PM
  #79
Do you have any pics of the heads? I sent you a private message the other day, with my email info. You can email me pics and I could post them here.
Old 04-13-2017 | 08:43 PM
  #80
Rookie's Avatar
Originally Posted by phragle
Im building similar.. 454 mag bottom end (fresh) 731 cam, Al's Promax alum heads and a 525sc blower setup. Should come out around 600 hp in a 22 foot boat.
Originally Posted by mike tkach
rob,i will bet you will make more than 600 hp by accident.will you be running it on a dyno?
600HP with a 731??? Subscribed
Edit, didn't read the 525sc setup. Easily doable!
Rookie is offline
