-   -   Rod ratio vs reversion (https://www.offshoreonly.com/forums/general-q/346042-rod-ratio-vs-reversion.html)
MILD THUNDER 04-11-2017 10:05 PM
Originally Posted by 14 apache (Post 4545577)
Boat ran around 106 with 351 brodix ovals that head will haul the mail and still have bottom end. Head hunter 383mc hurts the bottom to plane off. But they run like a bear.
What cam were you running with the 351's and the 383s? You have the 2.4 intake valves in the 383's? Looks like the 351 ovals have a 2.350 valve?
14 apache 04-11-2017 10:47 PM
276. 284 750 lift after lash. Yes 2.4 and 2.350.
MILD THUNDER 04-11-2017 10:54 PM
I know you prob posted it before, but i dont remember
You on the std bbc cam journal or 55/60mm?
Those things sound pretty wicked in your youtube videos i was watching a while back.
14 apache 04-11-2017 11:02 PM
Standard cams. The 2.4 stainless intake valve is rough on the intake lobe it weighs a bunch. Recommend a titanium crn coated valve for this. New set up is a 55mm 937 keys lifters and titanium intake with sweet 16 brodix heads. 12.5 Cr and avgas. On hold for now.
