Edelbrock 750's ?  How big of a motor? >
Old 10-11-2002 | 07:00 PM
MACDAD260's Avatar
Charter Member #818
Never heard of checking the valves that way but, probably not a bad idea. I assume you have someone else drive when you are doing that.
MACDAD260 is offline
Old 10-11-2002 | 07:01 PM
Engine box check- open up the hatch and look around for what ever.Vacuum gage tells me alot but most important if I have a vacuum leak.Offshore 5 years 100 ton tug 330 ft. crude oil barge.
FloridianSon is offline
Old 10-11-2002 | 07:03 PM
MACDAD260's Avatar
Charter Member #818
Old 10-14-2002 | 11:02 PM
OkieTunnel's Avatar
750's should be good to around 5200 RPM in a 502 easy.
CFM=502cid x 5200rpm divide this by 3456.
This number is then multiplied by volumetric efficiency which will be between 80 and 100% for a recreational engine. Even at 100% it needs 755 CFM. Your mild engine will be below this V.E.
If you don't have enough carb you don't lean out. The only way you can lean out is if your carb is not metering enough fuel for the air it passes. A 750 cfm carb will only pass 750 cfm or so of air. As long as you don't have a clogged jet or a vacuum leak too small of a carb CANNOT detonate an engine. Too low of jetting can if it is not metering enough fuel for the air.
OkieTunnel is offline
Old 10-16-2002 | 05:15 PM
timucin's Avatar
exactly!
timucin is offline
Old 10-16-2002 | 05:19 PM
Audiofn's Avatar
Charter Member #232
Thanks guys this is the kind of info I have been looking for. I guess I will hold onto them for a bit and see what I get for engines.
Jon
Put your best foot forward!
Audiofn is offline
sacaja
Cigarette
0
05-06-2008 11:56 AM
TeamSaris
03-10-2006 08:03 AM
BAD-HABIT
4
05-11-2003 09:05 PM
US1 Fountain
05-11-2003 06:04 PM
Bad to the bone
07-22-2002 01:34 PM
